Brake lights stays on
I had it with my dodge :mad: from one thing to another :spend: Where is our brake light switch ? is it at the pedal like most other trucks ? and else where ? and if some where else where and how easy to switch one out ?
  • Replies 13
  • Views 3.2k
Pull the knee bolster out and the switch is right there near the pedal arm...
by knee bolster you mean the plastic cover in front of my knees while driving ?
Are you talking about your tail lights or the E-brake indicator?Here is the taillight switch on the brake pedal.
the brake lights on the back of the truck stays on its like I am pressing the brakes while I am outside the truck 3 of my neighbors came knocked my door yesterday to let me know I forgot my lights on :lmao:
Pull the switch off and push on that button and see if the lights turn on and off. Pull the connector and they should turn off, if that turns them off you got a bad switch.
yea going out to the garage in a bit to lay down upside down under the dash ( my favorite spot to work on my truck anyway ) :rolleyes:
is that the piece that is underneath the steering wheel column?
ok..i know where we are at now...so the white or the black plug?
If it is like mine you just grab the switch, turn it about 45* and pull it out. Then there is an adjustment (been a while since I fooled with mine) that you set long and it will self adjust. Just press on the pedal, put the switch back in, and let off the pedal. Real simple once you get to see it.
I did have a bad switch replaced it with one form auto zone for $10 it was very simple to take out and replace once that panel was off
