Any Procedures For Testing an ABS Wheel Sensor?
1999 3500 2WD with 4 wheel ABS
Got an ABS warning light (along with a brake warning light). Rear sensor was replaced by previous owner - no fix. Took to dealer to run the diagnostics, results point to a R/H front ABS wheel sensor. Before I order the part (OEM MSRP = $200), I was wondering if there was a method to check the sensor with a meter or something. Is it possible that the sensor is just dirty with brake dust, or do the connectors get corroded? I guess I could compare the ohms resistance reading from the rt front with the value taken from left front. Any other tips or tricks would be appreciated.
Thanks,
Joe in St Louis
Today I did some investigating. First I did a visual to ensure the wires didn't looked damaged (no problems), then disconnected the QD on the Rt fender well & tried to take a resistance reading on the sensor (open-no continuity). Went ahead & removed the Rt front tire/caliper/hub to expose the sensor. The sensor was cracked wide open in two places - looked like it had filled with water which froze & busted open. There also was ferrous magnetic fuzz all over it. I think I found my problem.
Cheapest replacement part was from Mopar Wholesale Parts
http://www.mopar-wholesale.com/mopar-parts-online?gclid=CNqhvfWaxKUCFY64Kgod9zrIYg
at about $135 + $12 shipping. OEM parts at a good price, or so it seems. Plan on calling tomorrow & ordering.
Joe in St Louis
Yesterday the new sensor showed up. Bolted it on, plugged it in, and the abs light is no longer illuminated - didn't even have to drive it down the road! Glad to have it fixed.I did take a resistance reading on the sensor prior to installation. I only have a digital multimeter, and when taking a reading in the ohms function it registered open, but I've had problems before with taking readings on ignition coils using a digital VOM - need to get a Simpson meter. I switched it to the diode check function and was able to read a resistance of 1.106 ohms.So for troubleshooting a sensor, check for continuity, then physical damage.Joe in St Louis
