Here it is
  • Replies 8
  • Views 2.3k
Very cool, but on my 'puter, it sounded like a 12 valver!!!:smart:
Take that back! If my truck ever started like a 24V I would fill the crankcase with sand. I can't stand how they all start exactly the same no matter if it is 0 or 100F, and each truck starts identical to the next 24V. 12V's all start different depending on rust holes in the exhaust, idle setting, and everything else that gets out of adjustment or falls off. That is what makes each and every one special :lmao: Mine has never even started the same twice, it's variable starting transducers kick in to make sure it never reiterates how it started before. :lol:
i thought those came off with the CAT and muffler :lmao:
No, they are part of the muffler bearing design which I left hooked up. I read that they were an intricate part of the entire principle of an "efficient diesel engine". I do need to repack them though.
maybe i should have left my muffler bearings on, then i could have swapped a 12v variable starting transducers into my truck, and use it to refill my blinker fluid
Here is the best price I have seen on muffler bearings: MUFFLER BEARINGS You will need to keep an eye on this to see when it is back in stock: BLINKER FLUID
:lmao2::lmao::lol: The only thing they forgot was the magic sand :lmao2: I do need some of that seasonal air though :smart:
I personally will only run synthetic blinker fluid. Has anyone seen a good price on a CAN OF HONK lately?
