the cts is a bad mamma jamma....a coworker bought a new 1 in ~06 with a 3.6 gasoline direct injection. lets just say that 140mph down I-10 happened quite often. with the traction control on you cannot spin the wheels(no matter how hard you try), but with it off, you can break them loose with NO effort. i don't know if the VVT is thru the use of "extra" cams or hydraulically controlled. the whip picked up more poon than you can shake a stick at :drool:
Which new caddy model runs the vette engine in it? I have seen advertisements and heard talk of it several times. they are awesome looking cars.
The XLR is built in the same plant as the corvette on the same frame and everything. I've got behind a few of them, they are wicked. Oddly enough, it doesn't have a corvette engine. The CTS-V (what John is linking everyone to) is what has the vette engine.
