2001 cummins transfer pump voltage
- Replies 7
- Views 5.6k
wagntagn 3 posts
Mopar1973Man 2 posts
volkswagon 1 post
Blueox01 1 post
Does anybody know the voltage when starting .When I turn the switch to on I m picking up 12 volts for 2 seconds & then it drops to 8 volts? Then when I turn the switch to start & let go I get 12 volts for 25 seconds then voltage drops to 8 volts? Why does it drop to 8 you would think it should drop to 0 volts.These test are done at the transfer pump connector.
