Should I get the kit to resleve or just new seals? Also any videos on the subject?
If you can see a wear mark on the crank use the sleeve kits,if not just a seal.Big thing is to make sure the crank is clean and DRY,no oil should be applied to the crank prior to new seal being installed.Last one i had to buy(rear seal) was $80 from frieghtliner.It should come packaged over a plastic installer,so all you do is slide if off the installer onto the crank.:2cents: Did you end up getting a used engine that your rebuilding?
Yea it's used with 180k it's real nice and clean except where they took puke bottle off and let it drain on the eng.:doh: The only real bad thing I have found is when I ask what kind of oil he ran he said, what ever they have on sale at the quick lube place:doh: :doh: :doh: :doh:
