Driving yesterday,and layed it to the throttle(not any harder than i have before)now truck is running like crap. No codes,lot of white/light grey smoke from exhaust. Real rough idle,not any better above idle.:banghead:
Blew and intercooler boot or clamp ? Check boost fittings ;)
Here you go...
http://mopar.mopar1973man.com/cummins/2ndgen24v/diagnostics/diagnostics.htm
Excessive White Exhaust Smoke
[*]Check for air in fuel system.
[*]Check for coolant leak into combustion chamber.
[*]Check for DTCs set or intermittent DTC malfunctions.
[*]Check for block heater malfunction in cold weather.
[*]Check for engine coolant temperature sensor malfunction.
[*]Check for ECM not calibrated properly.
[*]Check for clogged or defective fuel filter.
[*]Check for poor fuel quality.
[*]Check for fuel heater or fuel heater temperature sensor malfunction.
[*]Check for malfunctioning or loose fuel injector.
[*]Check for fuel injection pump malfunction.
[*]Fuel injector restricted or blocked fuel injection or supply lines.
[*]Check for fuel transfer pump malfunction.
[*]Check for Intake/exhaust valves not adjusted properly (tight).
[*]Check for intake manifold heaters or intake manifold air temperature sensor malfunction.
[*]Check for internal engine damage.
