MPG loss towing minimal trailer
- Replies 6
- Views 4.3k
flagmanruss 2 posts
Mopar1973Man 1 post
MnTom 1 post
AH64ID 1 post
I don't have numbers but I know my MPG takes a dive. Since my overhead is still accurate (stock) I habitually leave it on... & see an immediate loss in the AVE MPG. I have heard similar comments from others. In my case, the trailer is a simple 16' single axle landscaper's trailer. No brakes. It does have the expanded metal mesh ramps. It I'm running empty, I can & have laid the ramps forward flat on the deck with a tiedown, though never checked MPG like that.
I'm not hauling hay anymore but this is the only pict I have available. It does give a good idea of the trailer & the amount of nose high angle.
I do notice the the trailer is still a bit "nose high" despite the 4" drop on the hitch insert. I had the insert & it works. I wonder if the trailer is catching air underneath the way a lifted truck does...
I have regreased & adjusted the wheel bearings but was unremarkable.
I find it hard to believe that such a nothing trailer has a significant impact on MPGs.
