Well turn out I finally replaced the fuel filter in my truck which was not too hard. Besides the fact that dodge switched the DAMN fuel filter housing therefore I need to buy the updated housing and filter. Well 73 dollars later I had the new filter and housing. It was quite simply. Tools needs8MM socket for 8 screws.Pan to drain fuel into2 hands.:duh: Drain fuel - Takes forever.Take fender off- 8 bolts very easy.disconnect WIF sensor and screw the drain line completely off.With your hand twist off the filter.I did take the tire off but because I need off for a different reason which did not busy not necessary. I bought the truck about 1 month ago and found the CV joint in the front drive shaft horrible out. I got in contact with the salesman he said they will cover the cost. Thank god! Sorry no pictures but i can post some next time. I just wanted to get it done this time.
  • Replies 4
  • Views 4k
I haven't followed the newer rigs but I have seen 2 newer rigs like yours along side the road with blown up transfer cases already. when the t-case explodes it is usually always due to a bad CV on the front driveline. Looks like they have a issue here. Unless people are not greasing them as I know they went back to greasable cv's in the 3rd gens and most people don't know how or where to grease them. Good to see you caught it before dynomiting the t-case.:thumb1:
Ya, I got about 80 miles I need to drive to get the thing back to the shop.
I hear a few mods coming on. Like a relocated fuel filter with updated media...:rolleyes:
The upgraded housing is very similar to your 02 and not a big deal to change, and the F2 filter it uses is very hard to beat.
