Replaced VP44 and Lift Pump Truck won't start! HELP!!!!
I just replaced my injection pump and lift pump. I put a factory replacement raptor lift pump on. After bleeding all the lines the truck will start and run fine. Once you turn the truck off it will start and run for 5-10 second and shut off. After that it will not start back until you bleed the injectors again. Please help.
  • Replies 4
  • Views 2.2k
Some where you got a air leak into the low pressure side. Since your dealing with all the old school banjo bolts double check all your sealing washers and be sure they are in place. Then if there is any fuel leaking most likely that is your air leak. Now that said there might be a seal leak problem on the suction side with the quick connector. Tip: Park the truck nose down and see if the problem disappears... If so then its a for sure air leak.
Did you get her to start and run steady?
I found my leak on the banjo bolt that goes into the lift pump. We must gave dropped one of the gaskets that goes against the pump when we were putting it back on. Couldn't find it until it was dark and shined a flashlight, we saw the diesel spray in front of the light when we turned the truck back off. Thanks for the help guys.
