Adjusting AirDog 150 pressures...
- Replies 21
- Views 17.8k
Mopar1973Man 9 posts
bahrfly 5 posts
jlwelding 3 posts
Dave3500 3 posts
Well I found a way to adjust the fuel pressure upwards on my truck. I started out with 16-17 PSI when I first installed it nearly a year ago. But now the pressure slipped down to about 14-15 PSI. I had some time on my hands a found a way to adjust the fuel pressure. Adjusting Shim...
I was digging around the shop and found a exactly prefect fitting washer that doesn't interfer with fuel flow and fits inside the pump. Its a cheap 5/16" flat washer but you going to need to match it up against the fitting to bet sure it not blocking the hole nor too large for the fitting. This is stuffed back in behind the return line fitting. Order of install... Ball, Spring, Washer, Fitting... Now I started out with 3 thinking there thin... OMG! 25 PSI... Pull one out 22 PSI... Pull another one out... 18 PSI... I happy again... ;)
