How much fuel pressure to high pressure pump? Your input helps
- Replies 9
- Views 12.6k
Davez 2 posts
ISX 1 post
98whitelightnin 1 post
busymountain 1 post
I am getting issue like not enough fuel I believe. How much pressure and volume do I need to supply my 94 high pressure pump? I bought a small electric diesel fuel pump but think it is not enough. I think this pump puts out 7lbs pressure, pretty sure its inadequate. The symptoms are: idles great but getting up to hwy speeds wants to cut out. It has similar symptoms to air in the fuel system. I have heard about FASS, air dog etc.. I want a simple pump that will put plenty of fuel/pressure to my big pump. Whats a good deal for the money? I want to install it in the engine compartment after the fuel filter. I know some of you don't like the idea of after the filter, but do you know any success stories. If installing the pump lower and closer to the tank is my best option for longevity that is fine but would prefer it under the hood. YOUR INPUT WOULD BE GREAT!
