Well I finally got around to cleaning up my RV275 injectors again...:duh: I've always had a random misfire problem with them at idle, only when hot. Finally got bad enough that I couldn't deal with it any more. I yanked them out and stuck in my stock injectors. In the mean time, I went out and bought a digital caliper for the tool box. So I figured I would pull them apart and measure the pintle needle, copper washer thickness, and spring shim.Kind of shocked at a few injectors... :truck:[TABLE=align: center][TR][TD]Copper Shim (Inch)[/TD][TD]Pintle thick end (Inch)[/TD][TD]Pintle thin end (Inch)[/TD][TD]Spring Shim (Inch)[/TD][/TR][TR][TD]0.0545[/TD][TD]0.1570[/TD][TD]0.1270[/TD][TD]0.0755[/TD][/TR][TR][TD]0.0525[/TD][TD]0.1570[/TD][TD]0.1270[/TD][TD]0.0690[/TD][/TR][TR][TD]0.0535[/TD][TD]0.1570[/TD][TD]0.1270[/TD][TD]0.0630[/TD][/TR][TR][TD]0.0535[/TD][TD]0.1570[/TD][TD]0.1265[/TD][TD]0.0710[/TD][/TR][TR][TD]0.0535[/TD][TD]0.1520[/TD][TD]0.1215[/TD][TD]0.0675[/TD][/TR][TR][TD]0.0540[/TD][TD]0.1570[/TD][TD]0.1265[/TD][TD]0.0675[/TD][/TR][/TABLE] Now #5 in the list has a strange sized pintle and nozzle. I verified the ID of the nozzle bore and the OD of the pintle and its a true fit of both. But looking at the part and how exact they must be to work properly, I went back through and cleaned them all and reassembled all 6 injectors. Then installed them in the truck and Man talk about a change. I was really really picky about them this time and actually checked all the measurements and made sure all the pintles and nozzles were spotless. So I'm back to running the RV275 injectors... :hyper:
  • Replies 5
So far they are runing prefect... Very smooth idle and lots of good power when you stomp the pedal to the carpet.Really changed the attitude of the running performance. Like ISX had done is soaked injector overnight in solvent and nothing happen... So now I tend to believe that most injector cleaner are incapable of removing any kind of gum or varnish on the pintle that gets cooked on the pintle. If you want it done right you just got to break them down and clean them by hand.As for #5 I double check it ID on OD and it a prefect match... But it showed me there is no way to interchange part of a injector with another injector...
Solvent is good for cleaning oils and grease off. For varnish you need something stronger like throttle body spray or a good carb dip tank. In the old days carb and choke spray would do it but the EPA didn't like what was in it so I don't even stock it anymore.
  • Current Donation Goals
    • Raised $20
