What Brake Pads are you using? 3500
That's correct. I don't have a lockup controller so I am not familiar with them and don't understand why and how they are used. I seem to remember there is some risk of something happening if you don't use it right.I took my truck into the Local Dodge dealer a few years back to have some work done and I asked them about getting an exhaust brake install and they told me I couldn't do it on the auto.Wasn't smart enough to challenge them on it and just took them on their word.So ya, I don't know any more than I have been told. And I don't even know if I have been told wrong!Is it really a viable option? Is there any risk to my truck with this lockout controller and I am guessing it is all a custom install. Probably even a special exhaust brake for autos? etc.
You can certainly have an exhaust brake with an auto. It will work a little bit without any modification. If you want it to work really well you will need a lockup controller. A lock up controller will keep your converter locked up for specific periods of time. Every controller works a little differently but the gist is they make the truck act like a manual. The automatic version may have a different way to actuate the brake than the manual. As far as I know they can be a little hard on input shafts, iat's, and map's. I used mine for a long time without any problems.The install for a controller will be different for each version. I have an ATS one and I think it was a mild pain to install. I did it myself. If I had to do it over I would get a BD controller.
You can certainly have an exhaust brake with an auto. It will work a little bit without any modification. If you want it to work really well you will need a lockup controller. A lock up controller will keep your converter locked up for specific periods of time. Every controller works a little differently but the gist is they make the truck act like a manual. The automatic version may have a different way to actuate the brake than the manual. As far as I know they can be a little hard on input shafts, iat's, and map's. I used mine for a long time without any problems. The install for a controller will be different for each version. I have an ATS one and I think it was a mild pain to install. I did it myself. If I had to do it over I would get a BD controller.
BTW, cajflynn, congrats on your million mile mark w your 53 Block! Amazing! Go CTD all the way! Dave
