91 ignition wiring help
Yesterday I had to go rescue my dad because the ignition in his truck went bad. He was checking out a roofing job and he got in his truck to leave and the key would not turn for anything, tried the spare key too and got the same result. So we took the steering column apart and fixed it so the steering wheel lock wouldn't lock the wheel up and then hot-wired the truck to get it home. Now on to what I need help with, Dad wants to keep using that truck, so till we can get the ignition fixed right I'm looking for a wiring diagram or something that will tell me what wires going to the ignition do what so I can wire something up so he can start it from in the truck and have the radio and everything. I've not had any luck so far with google.forgot to say that his truck is a 91 D350 without tilt steering if that matters at all.
  • Replies 5
  • Views 12k
My power to the starter failed, so I wired a push-button to the starter solenoid. Evey thing else off the key functions as before
Hold on let me pull up mitchell and see what i can find for ya
-Jordan-
here ya go
The last one should be the most help to you
-Jordan-
why not just replace the ignition switch?
Dad uses the truck for work whenever he can because it really out performs the ford he has in both power and most importantly fuel economy. We weren't able to find a ignition switch locally so we ended up having to buy one and it just arrived today. Thanks for the wiring diagrams Jordan even though I didn't get to see them till now.
wel you gotta keep dad happy. glad you got him up and running.
