Cracked exhaust manifold 98.5 24v
HelloDuring a routine valve adjustment the shop noticed that my exhaust manifold is cracked between 3 and 4. I plan on replacing with an aftermarket, they are reccomending the BD manifold, what is everone using? Is one better than the other? Also can about a 100 deg higher EGT than normal for the last 2 years that i could never explain no boost leaks whatsoever poor economy be chaulked up to the cracked manifold???Thanks eveyone
Hello During a routine valve adjustment the shop noticed that my exhaust manifold is cracked between 3 and 4. I plan on replacing with an aftermarket, they are reccomending the BD manifold, what is everone using? Is one better than the other? Also can about a 100 deg higher EGT than normal for the last 2 years that i could never explain no boost leaks whatsoever poor economy be chaulked up to the cracked manifold??? Thanks eveyone
For stock one call your local Frieghtliner dealer with engine# I bought one 4-5 yrs ago for $175,then grind all the slag/imperfections(help remove hot spots) from the casting, since then I've put 500k plus on this manifold.:2cents:
