Excessive oil leak coming from behind plastic cover behind ECM
oil leak coming from behind plastic cover. I suspect stamped-metal side cover is leaking. Any thoughts? Can i buy gasket at NAPA(cummins part number?) or need to special order from dealer?I thank you in advance for your feedback
  • Replies 10
  • Views 3.2k
Real pain to get to the front bolt/nut(can't remember which it is) under the vp44:banghead:
do i need to add sealant to the gasket when i assemble?
Yep referred as the tappet cover gasket by napa. Got a gasket and sent it over to the local college for there diesel students to fix. Best part no more leaks and free labor!
okay, so the problem was the gasket after all. toughest part of the change was getting all the way back and removing the disel fuel return "tee" to get that bracket out of the way. thanx all for the feedback.
