DO NOT TRUST THE MINDER We had a lot of trouble with them down in the coal mine when they show it is almost to late. Need to check it every oil change. I change my at every oil change also the fuel filter. Better be safe than sorry. I know some of you do not need to change oil from the filters you run so change the air filter with the money you save on oil change. GOOD LUCK
:smart: A periodic inspection of under hood components will help in preventative maintenance. I checked my filter minder before I installed. Worked just fine. A drop in MPG's and I'm sure some other changes would point to a restricted air filter. Given the fact as long as I don't drive my truck in the coal mines. :wink:
