Are there any injection pump rebuilders on here? what is the best way to go on rebuilding or going new on injection pumps I know the less expensive is the rebuild. I don't get on here much because i am working most of the time.
  • Replies 5
  • Views 2.3k
As far as I Know a reman is all you can buy. I have not seen a new pump you can buy. At 1k for a reman i cant imagine what a new one would cost.imagine what a new one would cost.
reman are all that is offered these days. I highly recommend getting one with all the upgrades and a NEW computer. many remans do not come with a new computer and you will end up with a dead pump much sooner than one with a new computer.
Thanks for the Replys i will go with the rebuild.
Here is the list of rebuilder I know that have all the tooling... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/247-bosch-certified-vp44-injection-pump-rebuilders Now don't let this sway you from using a vendor but make sure to ask the vendor who he's getting the pump from and about warranty.
http-~~-//www.youtube.com/watch?v=V0Q8qQ2UKRI
So as you can see all pump must be tested for a long series of test and pass every test before the PSG is even gets flashed with new software. So the idea of just rebuilding a pump and it missing the test bench is not going to happen nor is a weak or failing PSG computer going to make it past the test bench. Killing myths one at time...
