12v and 24v tappet push rod gasket
Thanks IS this the tappet cover for standard 12v tho ? I heard that the 12v cover has a breather than you can use/modify to have another crankcase vent. http://www.puredieselpower.com/catalog/9498-dodge-59l-valve-cummins-diesel-tappet-cover-insulation-panel-p-25489.html
Yes that is the standard 12v cover and it has the breather hose barb on it back by the stock fuel filter location.
