Kickdown linkage
Just learned something new on the 1996 Dodge Ram 1500 (5.9L V8 Gasser). I've always had a weird shift pattern where the trans would kick out of 4th and into 3rd hold for a long time and then shift up if you let the throttle out to near idle. Finally got off my rear and desided to look into this weird issue. So I started with the kickdown linkage. When I read up on the linkage adjustment it sohlud move together. I figure I better check the lever on the transmission. Guess what I found a spring hanging in the hole of the arm and the lever wasn't returning all the way back because said spring wasn't hooked up. :duh:So Hooked up the spring and re-adjusted the cable and shift issues are gone. It shifts really good... Not to hard and not to mushy... :thumbup2:
