Edge Comp and Scangauge
Hey guys, just wondering what boost readings you all are getting when using scangauge 2, and edge comp, i get like 14psi boost showing on scangauge after changing map sensor with a genos garage unit, old one read .-0.7 at idl, and would track slightly behind actual shown on isspro gauge, new one tops out at 22psi on scangauge.Thanks
  • Replies 3
  • Views 2.3k
Mine starts out at about 28.6 and goes to 33.7 if I remember right... I never used the SGII for boost reading but its was good for seeing if the sensor actual changes... That's about it... Actually the SG displays PSIa (atomphere) so at idle it should be 14.3 PSIa (0 Boost) and then go up to about 22-25 PSI or 25+14.3=39.3 PSIa
I've got video coming really soon! Processing as we speak! :thumbup2:
Here you go...
http-~~-//youtu.be/7RhrgFWaIvY
Wished my boost would hit that high lolSent from my PC36100 using Tapatalk 2
  • 3 months later...
I will try that on map setting instead of boost setting.
