My friend is trouble shooting a problem on his truck and is wanting to try my ecm. His is a 2001 with a 6spd. Will mine work on his truck? If they're not compatible and I did do it could something be damaged? Thanks.
  • Replies 3
  • Views 1.5k
his bing a stick it will not work this is why some 5-6 speed convertions dont work you need too run the ecm from the stick truckbeing a electericeal part i would not try it anything could happin then your truck will be dead alsohe will need to find one out of a stick truk to play with
THRacing is right you got to be careful of the truck of truck your running against. There is roughly 47 different ECM's out there so some may work good for testing and others might not work good at all...HO (6 speed)SO (5 Speed)SO (Automatic Trans)FederalCaliforniaCanadianList goes on...:whistle:
