i was going to do ball joints.....but i changed my mind
- Replies 10
- Views 2.4k
dripley 4 posts
02cumminsdude 3 posts
Mopar1973Man 2 posts
dodgethis91cmns 1 post
so i have an upper ball joint that seems to be squeaking and making all kinds of issues when im stopping. Mainly that it pulls to the right a little. So i figured i would get some quality ball joints. And then i proceeded with the order button and this is what i ended up with-prothane 2" leveling kit for the front-daystar scorpion +2" shocks-reybestos upper control arm bushings-reybestos lower control arm bushings-reybestos prefessional grade upper ball joints-raybestos professional grade lower ball joints-moog problem solver sway bar end links-reybestos professional sway bar bushingsill have pictures of it as stuff rolls in. i plan on tearing the whole front end off and putting it all on. I figured if your gonna tear it down might as well replace it all at once.:shrug:plus im going for a better stance a little nicer ride
