Harmonic Dampener
Okay, so I gotta get the dampener off to fix my crank seal. I do not remember it being so hard! I do not have a barring tool and it would be 4 days out at the earliest. I do not have that kinda time to wait. Is there anything I can do to break the bolts free?I thought about whether or not I could put it into Drive and break them that way. Would that work?
  • Replies 6
  • Views 1.6k
Either take the inspection cover off for the flex plate or take the barring tool plug out the front passenger side of the bell housing and stick a bar in the ring gear teeth to hold it. Would be easier to have an extra person to hold the flywheel to crack the bolts loose.
So putting it in Drive won't work?
Now you are making me feel better. I almost told you to put it in park:doh::doh:
Its an automatic. No matter what gear you put it in the flexplate and converter still spins freely with the engine, its a fluid coupler drive system. Its not like a manual tranny which is mechanically coupled to the engine.
I figured that out when is was typing the park idea and deleted it. hence the double dumb a__ on me.
Haha, its been a long day. I got under the truck, took off the inspection plate for the transmission, and "BING"! :duh: Then I remember its along these lines and thats why it won't work. I just grabbed the wife and had her hold a prybar on the flywheel as I broke the dampener bolts. Worked reaaaalllly well! I'll be doing it that from now on. Hopefully will be one of my last times having to do it!
