Key trick VS scanner, code reader and laptop do not agree....
- Replies 3
- Views 2.2k
Mopar1973Man 2 posts
Haggar 1 post
Sorry guys this could get a bit long. So I will try and stay on point.
Key trick shows 1 PCM code P05000 and 2 ECM codes p0222 and p0217. (I do have a SES light and solid BRAKE light showing on cluster)
Since these appeared after some major repairs, and during a new frrp install, I tried to just clear them and see if they come back.
I first connected an Actron CP9035. It showed only the P0222 code, and would not clear it.
Ok, so I pull out my Auto X-Ray EZ-6000. It connects fine (a bit slower than most other cars, but connects and shows intake air temp, throttle position, coolant temp, vehicle speed etc in real time) It sees only 1 code p0222. It will not clear it.
Ok, so I get the laptop and carcode. It connects fine, I can see many things (basically the same as the 6000). It sees one code P0222, and will not clear it.
Now, I get the that the P0222 could be a hard code and maintaining the problem (though the trouble shooting shows that this SHOULD only occur with the ignition ON AND engine RUNNING, It theoretically could be cleared during a key on engine off connection) I might not be able to clear it.
Has anyone else shown a discrepancy between key trick and actual codes?
That is my main question.... I will make a couple other posts on how inconceivable it is that there really is a P0500 or P0217 code in reality (could they be ghosts?).
Thanks,
Hag
