We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 11
- Views 2.1k
Mopar1973Man 6 posts
idahocountryboy 4 posts
dripley 1 post
Popular Days
Did This Forum Post Help You?
Mike, I saw on Cummins Forum, your/the tire pressure formula.
(Axle weight / 2) / Tire Capacity weight ) x Tire Max Pressure = Infation Pressure.
So my 'normal formula is:
Dual Rating:
((4200 /2) / 3415 x 80 = 49.19 psi
Single Rating:
((4200 /2) /3085 x 80 = 54.45 psi
My question is do you add the load weight over the axle, ie. pin weight, or w/e weight is on the axle? If not, why? The tires still bare that added weight to the truck.
So would the the formula look like this with pin weight of 3000 lbs.?
Single Rating:
((4200 + 3000 /2) / 3085 x 80 = 93.35 psi?
Dual Rating:
((4200+3000/2) / 3415 x 80 = 84.33 psi?
Second, do you use the Single rating or the Dual Rating and why?
