- Replies 51
- Views 28.5k
texas503 22 posts
ISX 18 posts
Mopar1973Man 6 posts
Rogan 2 posts
I recently changed injectors to 5x0.010, the truck runs great, but I had a question as to what EGT is normal for these trucks. This is what I have.1997 2500 auto 4x4; #0 plate full back (as in toward the cab); 3.55 gears; 265/75/16 tires; ranch hand bumper; AFC full back; Starwheel full forward I think that is all that would affect EGT.My EGT doing about 55-60 when climbing a relatively small hill will rise to 800 degrees easily and sometimes 900 without me accelerating. I will be doing about 7-8 psi of boost and EGT will climb rapidly. Just under normal acceleration... taking about 30 seconds to reach 60mph, egt will reach 700-800 degrees. Doing 70mph EGT will run about 700 degrees on flat and 800 up a hill pushing 10 PSI.And I have done a boost leak test.Is that normal, just seems a little hot for normal driving? It has been about 100 degrees around here, does that really make a difference?Thanks
