I've got a 98.5 24v 2WD and 47RE auto, 175k miles. When I first start the truck, it takes a long time for the trans to shift from 1st to 2nd. After that, it shifts fine thru all gears after a stop sign, light, whatever. If I turn it off and go into a store or something, when I come back and start the truck again, it takes a long time again to shift from 1st to 2nd. After it does, it shifts fine again. So, it happens whether the truck is cold or warm and only the first time after I start it. My last fluid/filter change was about 25k ago. I have a slow leak that I haven't found yet (I have seen tranny fluid on the ground behind the right front wheel) so I keep the fluid level topped off. This just started last week. I've read the entire forum and saw others with the same issue but theirs seems to happen all the time - not exactly the same as my issue. Any ideas?
Possibly a bad 1st-2nd shift solenoid? or bands need adjusted. just a few ideas but i'm no Tran expert i'm sure some one else will chime in here who knows more.
