A/C Problem
My issue started about a month ago. Up until last month i was able to Idle the truck with the A/C on with no problems of humidity within the cab. I am having the issue of not being able to cool the cab. The A/C clutch is working because i hear that thing engaging a block away:lol:. I start to drive the truck around and A/C comes back and starts pushing cold air again. Has anybody had this problem?
the low side was about 106psi? does that sound right to you? maybe compressor is out?
Update! Compressor went out:mad:. Took it off and it seems that there was no oil within the pump. Haynes manual says to pour oil out of old one and pour into new. When i did this, :stuned:, nothing there. Thanks y'all for your feedback. check that oil in the compressor, i got hit with :spend: .
