If your talking about removing the cv joints from the differential, they are held in by a snap ring. Once you have the outer part of the joint removed from the hub, they should pop out with a good tug (in a perfect world of course). If its been a long time since theyve been apart, they are probably rusted in there because they are not lubricated by the gear oil like youd think they should be. Ive used a big slide hammer with a 3 jaw adapter and used a little elbow grease to get em out.
What 420 ATV do you have? I happen to have a 2008 manual for the Honda Rancher 420. Let me know I'll dig up the PDF file and email it to you. :wink:
It's a 2009 420FPA (I think I got the letters right!) Independant rear suspension and power steering.
Well mine wasn't rusted in cuz it somehow came out on its own! I pushed it back in not realizing it'd lock in and now I need it out to reassemble everything!
You should be able to give it a good yank if its already been out once the only thing that holds it in is a small clip at the end of the splines. You can also try GENTLY prying with a good sized pry bar between the differential and the cup of the cv joint. Just be careful, the differential is aluminum and on my Rincon there is a mounting ear that could break off if you abuse it too much. Like I said earlier I had to use a large slidehammer i started off on the end of the cv joint hooking the slide hammer up to the hub using the lug nuts. I had a helper keeping the cv joint straight while I hammered the snot out of it. The inner cv ended up coming apart so I then had to switch the ends of my slide hammer to a 3 jaw puller. The jaws just barely grabbed the out side of the inner cv cup (this was all that was left sticking out of the differential) and used tie wire to keep the jaws tight to the cup. I beat the snot out of it with the slide hammer until it eventually came out. Then i used a brass drift pin to reach through to the other side and took my bafh and drove the other cv out. Hopefully you dont have the problems I did, it doesnt sound like you will if its already been out. I think its a bad design, the cv splines go straight through the differential yet they are not lubed at all. So like in my case, I have a 2005 Rincon with nearly 4 thousand miles thats been rode hard, been in lots of water and mud. Now I wash my machine after every ride, have installed grease fittings in all bushings in my a arms, and keep up on the maintenance like clockwork. So its not a matter of neglect by any means. Just a poor design :mad:
