Injector swap question
So I got my RV275s in the mail today. I have a question on the removal of the old ones. I don't want to pull the lines off the pump end, but I got new O rings for the transfer tubes so they have to come right out. Can I just loosen the hold down brackets and gently move them out of the way enough to get the tubes out? I have checked the net and watched pepsiocean's video so I'm all good with the rest of the procedure, just not sure about the lines is all.
  • Replies 2
  • Views 1.2k
Yes, leave the lines hooked up to the pump but pull out the 5 or 6 8mm bolts holding the lines to the intake plenum. Make sure you pull the tubes before the injectors or you will booger them up.
