Replacing OEM back up bulbs
Backing out of Dear Daughter's over Christmas... noticed lack of back up lights. (Driver's side out, passenger's came on... though it was still pretty dark backing out of her driveway.) I have a whole bin of bulbs... nope, not the right type. Off to the store I go. I buy # 3156... thinking single function backup lamps would be single filament. The lamps that came out are dual filament # 3157s. Well, I'd grabbed some spare # 3157s at the store, off the next peg, so I stuck them in... but I'm still scratching my head... Are these normally # 3157s or # 3156s? I'm trying to test the removed bulbs... look good... but it's like trying to hang onto a greased eel. (And, yes, again my bad fingers are a problem.) Thanks guys!I managed to test the old bulbs with my multi-meter... both filments test good in both bulbs Sooo I'm guessing that I have dirty sockets. It's snowing hard out there now... will check when it's not.
I actually thought my back up lights were pretty good until they weren't. I've used 'tuner cleaner' plenty on electronics but think the results are short lived. I think the chemical cleaner allows contacts to oxidize quickly. With trailer plugs, I use an old ignition file & emery paper. I think with this I'll try scotch pad pieces & that file first. I don't know if some dielectric grease would be good or bad.Still snowing...
According to the manual, they should be 3157's.
EXTERIOR LAMPS
LAMP BULB
Back-up 3157
Cargo 921
Center High Mounted
Stop
921
Clearance Roof Mounted 168
Fog Lamps 896
Headlamp - SLT 9004LL
Headlamp - Sport Low
Beam
9007
Headlamp - Sport High
Beam
9004LL
License Plate w/o
Bumper
1155
License Plate -Step
Bumper
168
Park/Turn Signal 3157NA
Snow Plow Control 161
Tail/Brake/Turn Signal 3157
Tail/Brake/Cab - Chassis 1157
Underhood 105
I replaced the bulbs & didn't fix the problem. The bulbs that came out tested ok, too. Some of the contacts looked dark & oxidized. As soon as I'm fit to go outdoors, I'm planning to use a 3M pad around a thin file to clean up the contacts & try again. I picked up a pair of Silverstar 3157's... wonder if I'd like them, assuming I can get them lit!When backing at night, I'm used to dropping to parking lights which helps my eyes adjust to the rear light... This cold or whatever is hanging on. At least I'm not on the immune suppressing MS treatment anymore. (Any infection, cold or flu... upregulates the immune system & makes MS symptoms very much worse... Can't say much more without engaging the word censor!)
