Well, this morning after changing my fuel filters i was in the process of jumping power from the battery to the plug for my raptor to bleed the air out of the system when i had a brain fart and grabbed the plug for my deleted fuel heater instead. There was a spark and immediately put the CEL on. So i grabbed my smarty and checked the codes...p0222 idle validation...p0113 IAT sensor voltage high p0118 ECT sensor voltage highp0238 MAP sensor highp01693 companion code I figured i just blew those sensors so i went and picked up a new ect,map,and iat sensor and installed them, cleared the codes with my smarty and lo and behold those codes pop back up again. So in desperation i tried leaving my batteries disconnected for an hour with no luck. Is there a relay or something else that i might have fried? or?
Man I'm sorry to hear that.... I did something like that.... I hooked up my brand new Raptor fuel pump and couldn't figure out why it did not work :lol:. Confused me to no end for about an hour...I had both leads hooked to the positive.Another time I ruined a 300 dollar charger hooking it up to the battery backwards :spend: I also put 14 gallons of gasoline in my truck before I realized:whistle:
ALWAYS disconnect the batteries (both) when working on the electrics. Any kind of short will put a spike in the system and you just found out what the end result can sometimes be. A hint, BEFORE installing the new ECM, disconnect the batteries.
