Have a 47re (truck in sig) need to replace All tranny lines. Would like to go all screw in fitting, no OEM plastic coupeling ?$@%. Anybody know a one stop shop for fittings &lines. Thanks Dave i.e. tranny to torque tube cooler to air cooler & return to tranny. Tube & air both have the plastic TAB coupeling.
  • Replies 5
  • Views 2.4k
I just went through this, basically. the air cooler to trans rear, and trans front to side cooler are available (Oem style). The side to air cooler seems to be dealer only, even though Dorman has a pn# and stocks it, I couldn't find any reseller that could order it. Ive fixed the 47re's 1/2" with brass compression couplers (standard union) This might be an option for making your own connections.
Thanks Rogan, have any pics of your lines with this coupeling? Would like to beef up lines, thinken perfab some hydraulic and compression swivel fx. Don't know if this will wk on front , side cooler in and out. Will the fittings on side cooler unscrew from tube if the mounting plate is taken off? Thanks Dave
I have all the lines I took off my 98 when I swapped in the 5 speed, they are rust free and yours if you want them.
my truck has all metal fittings.but if you want go to a line shop and get them to make you some hydraolic line that is rated to 300F, and have them put ends onto it i have heard that works.
Pepsi, are the lines and connecting coupplers OEM or after market? made by? any pics of connections at the side tube cooler, front fin cooler? I assume the lines are from the 99 and not the 08 in your sig.
