Greese Zert
jlwelding
Is it 4x4 and totally stock???If so, there will only be one. It's a needle grease fitting on the double cardan joint on the front drive shaft. Sealed u-joints, axle u-joints, ball joints and tie-rod endsIf it's a 2wd and totally stock, there will be no grease zirks anywhere. All sealed.
Most likely whatever greasables you can get from NAPA. That's where the shop gets most of their stuff.
Thanks. I have to do some looking this week. I just looked and realized that you can't just replace the tie-rod end on the passenger size, or the pitman arm joint....
