Howdy all, I've had my first Cummins, and diesel for that matter, for a few months now. Trying to learn as much as I can about these beasts. Found some of the best info on this forum so I decided to join. I've thrown a Mitusa pump and gauges on first thing. I hope to take advantage of all the knowledge and get all the other bugs worked out.
It's an aftermarket mechanical alternative to FASS or Airdog pumps, but runs off the crank via a toothed belt. It is similar to the DTT Assassin or Glacier Diesel's Fuel Boss. It has had rock solid pressure of 16-17psi at idle or WOT.
