New Vp44 is here... truck is de-tarred...
- Replies 7
- Views 2.2k
Mopar1973Man 2 posts
rancherman 2 posts
CSM 1 post
diesel4life 1 post
I should of never powerwashed the dang thing! I never would of found the snapped off peg on the bottom of the intercooler (or the crack leading away from the broken peg)... easy fix, I'll weld a 5/16ths rod to a fender washer, then JB weld the whole thing to the bottom of the intercooler.should have the new pump hung and plumbed by tomorrow... barring any new winter storms! But still waiting on the front crank seal.Son Rob claims the radiator is 10 pounds lighter now....power washed it back and forth for half an hour. Need to hit it tomorrow with soap to cut the last of the oil film meanwhile, I was under there trying to spot where all my PS fluid is running out... typical output shaft seals are gone on the steering gear. And there is quite a bit of slop in the shaft. I wont rebuild it myself.. Rockauto has several branded exchange units for 100-180$BTW, the new VP DID come with new electronics and new overflow valve. (DAP) I also see my idler is cocked over, and causing the serp belt to ride over. I guess it's better to get all this crap out of the way now...BEFORE it's time to haul cattle!
