Dana 70 pinion seal replace
My Son replaced the D70 in his 99 week before last with a limited slip unit he found at a local salvage.. He and his buddy were having trouble getting the Ujoint cap bolts tight so they opted to swap the yoke off his old axle:think:To make a long story short.. he now has a leaking pinion seal.Does the Dana have a crush sleeve on the pinion like a GM?? If so, any recomendations on how to torque the yoke back without changing the pinion depth??
  • Replies 5
  • Views 5.8k
No, they probably rolled the lip of the old seal in or the lip spring came off when they swapped it, I alway replace the seals if I pull a yoke because more often than not the seal will leak especially if you put a different yoke into a different seal that will always leak from my experience.
I googled D70 specs and they indicated the pinion has a shimmed preload.. No crush sleeve. Minimum torque spec was 220-330 lbs ft
You got it, I guess I could have expanded on My "No" lol..:thumbup2: I never torque them, I always tighten the nut down with an impact. After doing it for 20+ years it becomes a "Feel" thing and knowing your tools power. But if you are a weekend warrior then torqueing it is fine but it is hard to hold the pinion and keep things from turning while applying torque by hand.
Also have him check for any grooving in the yoke from the seal. It doesn't take much before no new seal will fix the problem. Had this problem on my Tx Case output shaft yoke.
