'99 24v wouldn't start
- Replies 7
- Views 2.2k
Mopar1973Man 3 posts
CUMMINSDIESELPWR 3 posts
Cowboy 1 post
OK a few day ago this happend and I wanted to know your guys thoughts and maybe what you think the problem could be.The truck, '99 3500 4x4 5spd CTD.OK it was about 50* outside, I started the truck, it started like normal, didn't let it warm up or anything. drove about 500 feet and shut it off for about 20 minutes. Tried to start it and it would only crank, didn't try to fire or anything. First I checked all the fuses, under the hood and in the cab, nothing. I then tried taking out the power puck thing, that splices in the plug that goes to the back of the Injector pump. I took it out and still nothing, put it back how it was and nothing. I then went inside and checked on the internet for any info and found that in order for the IP to inject fuel the red and black wires on the plug need to have positive and negitive power, so I went out to the truck and unpluged it again, took my multimeter stuck one probe in one plug and the other in the other. turned the key on and it had power, so I pluged it in and it started! I have started the truck more then a dozen times since then and it has started every time.Could I have scraped some junk away from the plug to where it made contact?Oh and NO check engine light.
