Code 1689
My lady was drving our 1999 Ram 3500 cummins turbo diesel, getting on the highway and throttling up when all of a sudden the check engine light came on and our big white truck slowed down to a crawl, 20 mph max. We limped her home and called a good friend of mine who has a code scanner, he hooked it up and it came up with a P1689 code. She will start up and idle, step on the pedal and she studders a bit a Safety shut down mode I suppose with the 20 mph max..Please help me get my baby purring again..Patrick
  • Replies 3
  • Views 2.1k
Another set of questions...Q: Do you have a fuel pressure gauge?Q: What's your fuel pressure like from Idle to WOT at highway speed?Q: What fuel system are you running?
Fuel filter?Lift pump?Injection pump? I'd check things in that order.
