- Replies 11
- Views 3k
cetanefreek 4 posts
dripley 3 posts
diesel4life 1 post
kingairc90c 1 post
I'm wanting to redo the fuel system on my '83 F250 with Cummins. Right now it is only using one of it's two 19 gallon tanks, the front tank. I'd like to replace the rear tank with a drop in replacement 38 gallon; and, would it be worth while to add a sump to the new 38 gallon tank?
Picture of a 38 gallon installed
I was thinking of adding a typical billiet $$$$ diesel sump to the lowest point in the tank pictured or using a formed steel sump more common in drag racing applications.
http://www.jegs.com/i/Jegster/550/40793/10002/-1?parentProductId=747210
My second question is which lift pump should I be looking at? I never plan on making big power, replace the stock turbo, the only thing I might do at a later point is add RV275 injectors and possibly a tuner. Stick with a FASS or AirDog? Build a system from scratch?
And last, I'd like to turn the the forward 19 gallon tank into an auxiliary tank that I could pump into the main 38 gallon tank. Would this be as simple a wiring a pump and plumbing into the return line?
