OK going to get the converter swapped, out what stall speed do you guys recommend. 1600 RPM or 1800 RPM. Truck gets dropped off tonight I know sort notice but any help would be appreciated.Don
  • Replies 3
  • Views 1.8k
1800+, do not do any tighter at all or you will be very unhappy as a daily driver or tow rig.1600 is a super tight converter, usually drag racers are the only that go low but that seems way to low for even them.
the Suncoast 3 disk is normally 1900.
