hose on oil return line from turbo
Just some silicone heater hose or even regular heater hose will work fine to replace that line.
high temp oil under pressure may be too much, thats why its a braided steel cased line so you dont get a heat burst. i wouldnt run anything less than stock IMO would suck to have it pop and empty your engine in seconds being tied to the main galley
If you have pressure in your return hose you have some real problems. Far as regular heater hose, I would not use it because the oil will deteriorate the hose causing premature failure. Cummins is another place and you can also try most auto parts stores.
