Yes. The AirDog supplied wiring will use the factory harness to trigger a relay to power the AirDog 150. But remember do not directly hook the AirDog 150 pump motor to the ECM leads. This will cause damage to the ECM. So if your missing the wiring for it I would contact either Eric @ Vulcan Performance or Pureflow for a harness.
That's what I was afraid of. Picked up a used airdog. Pump only. I'll need a bracket too. I assume that's something vulcans guys can get me too ?Sent from my iPhone using Tapatalk
You'll need fittings too. Bought mine through Vulcan. I went through the OEM filter as well (2 more fittings). You want to get rid of the restrictive banjo bolts. I also installed a tap (drilled & tapped elbow) for a fuel pressure gauge so I'd not have to break into the system later.
If not go directly to PureFlow. I just dealt with them on a warranty replacement AD-165 for a failed Raptor 100 and they bent over backwards to help.
