New injectors, possibly this weekend..
just for giggles, measure your backlash in your timing! Verify also everything in the timing case is lined up. U sure engine is tdc (balancer hasn't slipped) during timing test?
I had a 354 perkins that didn't idle worth a dang, turned out it had a hammered out keyway on the
crank. The bottom of the keyway was wallowed, plus the moon key also way undercut. When the key
was sitting in the 'way, it looked perfect! But I could rotate the gear almost a full tooth by hand.
Those symtoms weren't loping though, it was more like an occasional chirp or bark in the exhaust, from random cylinders.
Edited by rancherman
