Steering slack? Where to start?
- Replies 12
- Views 2.5k
comanche79p 5 posts
Mopar1973Man 4 posts
mehbohdi 1 post
CTcummins24V 1 post
Somewhat new to the Dodge so here goes. I thought my steering gear was getting some slack in it and had a helper look it over last night. I thought that I needed to adjust the adjustment screw some but after looking it over it looks like the movement is in the steering gear output shaft, not the gear adjustment. I know part of my issue is the 31" tires. I have a new alignment after upgrading to the '09 steering mod, checking the ball joints. Everything seems tight except for the movement in the output shaft. It acts like the bearings, if there are any, are out. My questions are, 1) Is this normal? 2) Is this why the steering brace/support is installed? 3) If I do install a support what to expect from the steering gear, should I go ahead and replace it now or just wait and see? Thanks for any help.
