Anothe fuel pressure gauge question
- Replies 30
- Views 8.1k
Lone Watie 8 posts
Mopar1973Man 7 posts
ISX 7 posts
guesswho512 3 posts
For 99 owners, where did you tap for your fuel line to gauge. My filter housing doesn't have anything on bottom to tap into like Mike's does. All I have on filter housing is the inline from the lift pump and the out line to the IP, both are on top of the filter housing. Also there are 2 capped ports on top, sorry no pics right now. Is the out line to the IP where I would thread in my tapped banjo bolt for the fuel line. Also, is it okay to run braided line all the way to mech. gauge, don't want isolator. Plan on doing the needle valve setup. Will braided line go into the gauge, i.e. will it thread into the port on the gauge itself, or do I have to do the nylon tubing kit. Thanks.
