Hard Starts On John Deere 455
- Replies 13
- Views 10.2k
JAG1 7 posts
rancherman 2 posts
Mopar1973Man 1 post
bh115577 1 post
My tractor has been running great for 13 years. Has about 800 hrs. All of a sudden it has very hard starts but, once it runs, it's very smooth at idle and any throttle position.
There is no water in fuel, no water in oil and has a new fuel filter. Air filter minder still shows good only moving about 1/4 of the way to the red warning line.
It has white smoke while cranking and then clears up and runs real good. It will start again real good, no hard start, if run again within about an hour.
I cleaned all electrical and checked fuel pump fuse connector and put in new fuse even though old one was good.
Do any you guys know what else I should look for?
It's a 3 cylinder Yanmar 22 hp.
Thanks very much
Mike
Edited by JAG1
