Hoping someone will know what this plug is for .....
Have an '02 RCLB 5speed
There is a plug below the ashtray in my truck.  It has a double row of 8 sockets (16) and the sockets are small.
It appears to be factory installed, but I just don't know.  The wiring is lengthy, and the excess was coiled up behind the kick panel - drivers side.
I've been de-installing the boom box sound system, and have a RAZ (optional-non Infinity) radio.  It has the auxiliary input ...
Any info on the plug would be much appreciated ....
  • Replies 8
  • Views 1.6k
Hope these show enough Mike ..... The metal bracket appears to be from the factory, but I don't know.
Thanks Mike.
What is the OBD ll port ... ?
Thanks
OBDII port is where you plug a computer in for diagnostics such as reading check engine light codes and more.
Everyone is correct that is the OBDII port.
You might pull the 3 screws on the bottom edge of the knee bolster and see if the wires are just zip tied to the ODBII port.
